Heat wave. How's your trans temp?
Old Aug 17, 2012 | 02:35 AM
Siciliano15's Avatar
oh ok. yea because i just drove home now for example. i got on the highway and the temp was at 179º. after 2 min it went up to 181 and then to 183 and then just stayed there. it was a little cooler out though so i guess maybe thats why it didnt get up to 200 on the highway.
Old Aug 17, 2012 | 04:31 AM
mjs1012's Avatar
I'm running straight through a big tube/fin mounted on the condenser.
With my cooler i never see 175 on the highway. I ran a smaller cooler after the stock one for about 2 weeks and found it tapered off when cooling on the highway and would stay at a constant temp and never drop.
Old Aug 17, 2012 | 06:50 AM
1nasty86's Avatar
Turd Gen Guy
I have a 4k converter and a big cooler with its own fan and on a 175 degree switch, its wired straight to the battery so even with the key off it can come on, driving in the middle of the day around town it will come on and stay on for a few seconds after I switch the car off and I never hear it after drivng on the highway
Old Aug 18, 2012 | 10:10 AM
LS-ONE_DAY's Avatar
I have a 30k Hayden 679 and newly installed custom FTI 3500 converter. I didn't hook up my Aeroforce for the way home, but according to the tuner when I asked him to look up trans temp after the dyno runs (5-6 dyno runs, 90* outside) he said the temp got to 179*
Old Aug 18, 2012 | 10:57 AM
mjs1012's Avatar
A little off topic but how are you liking the new comverter mike??
Old Aug 19, 2012 | 10:06 PM
so if im getting up to a max of 210º very occasionally in hot 90º+ outside temps do i really need an external cooler or would that still be considered a safe temp? i live in northeast so only 2 or 3 months of the year can get into the 90's
Old Aug 19, 2012 | 10:08 PM
senicalj4579's Avatar
You really should have another cooler. 210 isnt the worst but it def could be better. Get a cooler.
Old Aug 20, 2012 | 07:11 AM
LS-ONE_DAY's Avatar
So far so good, lockup is a little finicky sometimes, the lockup speed is a little higher than I'd like, like 46mph or so, so on some local roads it has to switch between unlocked and locked more often than I'd like and I have to play with the throttle for it to lock at 60 sometimes depending on how I accelerated to get there. Guess that's the nature of the beast though.
So far I footbraked it once on a backroad to see how high it would stall, I think it went to like 3k? Not really sure though I'll have to test it again, the first time I took my eyes off the tach to attempt to keep the car straight because I launched it instead of just letting off the gas.
Around town it isn't bad, it's tighter than I thought it would be, but as far as performance goes I haven't really gotten in it a whole lot yet.
Old Aug 20, 2012 | 07:21 AM
JUSTINSWS6's Avatar
I never get over 175 with this trans cooler
http://bmracing.com/?wpsc-product=hi...2-diameter-fan
In driving on the road not to much stoping stay at 130 ish
Old Aug 21, 2012 | 04:44 PM
mjs1012's Avatar
for how much that cooler cost it better keep your tranny cool lol.
Old Aug 21, 2012 | 05:30 PM
JUSTINSWS6's Avatar
It does real well. I had to get a tranny cooler i switched to a 3 inch griffin straight up radiator with no tranny cooler and ran that tranny cooler under the driver side blinker cant see it and gets air from the inlet under the blinkers
Old Aug 21, 2012 | 06:26 PM
  #32
LS-ONE_DAY's Avatar
Yeah I'd never want to spend that much on a cooler lol!
Old Aug 21, 2012 | 06:46 PM
  #33
JUSTINSWS6's Avatar
Lol for as much as i have in a motor and trans i want to keep them perfect and cool lol
Old Aug 21, 2012 | 06:57 PM
  #34
LS-ONE_DAY's Avatar
Haha very true, at a certain point another $250 is cheap insurance. I may upgrade coolers down the line but hopefully for a bolt-on/stalled car this 30k plate will be enough
Old Aug 21, 2012 | 07:17 PM
  #35
JUSTINSWS6's Avatar
It should be where is it mounted?
Old Aug 21, 2012 | 07:24 PM
  #36
LS-ONE_DAY's Avatar
On the front of the AC condenser right behind the front bumper
Old Aug 21, 2012 | 09:55 PM
  #37
mjs1012's Avatar
You'll be good with it there.
