Stalled A4's come in plz.....
from
http://www.f-body.org/gears/
70mph,standard tire diameter
2.73=1750
3.08=1975
3.23=2067
3.42=2200
3.73=2400
3.90=2500
4.10=2633
4.30=2767
4.56=2933
OEM tach and speedo can't be relied upon for accuracy.
GPS will indicate true/actual MPH
Unit such as ScanGaugeII will indicate true/actual RPM
2.73=1750
3.08=1975
3.23=2067
3.42=2200
3.73=2400
3.90=2500
4.10=2633
4.30=2767
4.56=2933
Would a bigger size rim make the rpms higher or lower?
Taller tires would make the overall gear ratio less (numerically speaking) thus requiring less rpm to turn so in fact if he was turning 3k at 70 his tires would be much smaller than stock if they were larger than stock he would be turning less rpm than everyone else with stock tires and 3.73's
. It's all the same after 40mph or so when the converter locks in it spins right along with everything else
