View Poll Results: Shift kit or Stall?
shift kit
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
0
0%
stall
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
0
0%
shift kit and stall
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
0
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
4L60E no staying in any gear??
![Unhappy](https://ls1tech.com/forums/images/icons/icon9.gif)
i have a 1998 automatic trans am just had the motor replaced by a shop and less then a 100 mils after i got it back (3days) the transmission slipped once and then just slipped out of gear and couldnt get it to go back in so i parked it and let it sit for a couple days tilli could push it home (it went out a block from my house thank God)
when i went to push it hope i started it and put it in gear and it worked like normal for about 3 mins and slipped back out of gear again and now after letting it sit for a while it will go in gear an slip out after it warms up.it does this in every gear R-D-3-2-1.
any ideas of what it could be? my fluids smell burnt and are discolored.
theres also a rattling noise when it 'slips' out of gear.
yeah im in the process of pulling it out in my driveway right now.
any hints or tips on getting out easier?
i got the driveshaft out already and dont think ill have a problem getting it away from the block since i just had the motor replaced
