Need a pump
Old Aug 12, 2011 | 10:34 PM
CheapPower's Avatar
Default Need a pump
Ok I need a pump for my 99 ws6. I have broken 3 pump rotors and I think the *** clowns that did the trans put the wrong pump in. I need a pump that is absolutly from a 99-00 ls1 fbody. I have bought a 4030 billet rotor and slide "im so sick of this rotor crap". but if you have a pump THE CORRECT one please let me know asap . Also if you have a force motor "on valve body " that would be great.. I gotta figure this stupid *** issue out
Old Aug 12, 2011 | 10:45 PM
Monzsta's Avatar
Check your flexplate. Also check for missing dowels on the block. The 4L60's pump is kinda fragile. If the converter isn't gently seated all the way in the pump will get broken instantly.
Old Aug 12, 2011 | 10:51 PM
CheapPower's Avatar
well I have tried it all... I probably will buy a tci flex plate ..but I just am trying to hit it all while its out.
Old Aug 13, 2011 | 07:58 AM
Gilbert@Ace Racing's Avatar
Give me a call. I might be a able to help you out. I don't ordinarily sell parts outright, but I might make an exception.
I'll be at the shop until about 3:30 today...
g
