which flexplate for turbo build? B&M?
Old Aug 21, 2011 | 10:07 AM
jks67ss396's Avatar
Default which flexplate for turbo build? B&M?
Hey guys
Ive got a lq4 turbo build going into my 67. just got the 4l80e back and wanted to pick up a flexplate.
Ive seen some guys use CSR or TCI but what about this B&M one? 20340
its SFI 29.1 approved and 140 bucks. vs 2-300 that others cost.
will it be up to the task?
thanks guys
Old Aug 21, 2011 | 03:34 PM
Yank's Avatar
You can look at our SFI LS1 flexplate it is $79.95 and will be up to your demands.
www.converter.cc
Thanks
Old Aug 21, 2011 | 05:24 PM
jks67ss396's Avatar
thanks man!
does it come with bolts? if not, what sizes/grades would i need?
and you have them in stock, right?
Old Aug 22, 2011 | 07:35 AM
Circle-D's Avatar
What converter do you plan on running? That might make a difference on which flexplate you can use. We have several options but need more info. And we have both the converter bolts and the crank bolts, no worries there.
Chris
