Check ball capsule replaced with cup plug, is this bad?
Old Sep 6, 2011 | 02:10 PM
GNXClone's Avatar
Default Check ball capsule replaced with cup plug, is this bad?
I currently have my 4l60e torn apart to replace a broken input drum.
While in there, I noticed that the check ball capsule near the servo bore has been removed and in it's place is a cup plug. Is this going to cause any unwanted side effects?
I believe that using beefed-up replacement hard parts and additional clutches is good. But, I also feel that mucking with the hydraulics usually leads to bad things, such as 2-3 shift flare.
All of the best shifting 4l60e's I've ever had have always been stock.
So, is there any reason I should NOT replace the cup plug with a new check ball capsule?
Old Sep 6, 2011 | 11:24 PM
sjsingle1's Avatar
i remember the trans go SK had some orifices that got plugged.......is that it?
Old Sep 7, 2011 | 12:49 AM
ramairws6's Avatar
We went this route on my last build up and haven't had any issues yet. My little ole' 4L65E has performed flawlessly so far.......
Old Sep 7, 2011 | 01:10 PM
GNXClone's Avatar
Wow, 10's at over 130 MPH on a 4L65E is impressive indeed! Curious though, how much does your car weigh?
Old Sep 7, 2011 | 03:21 PM
ramairws6's Avatar
3800 fully dressed....
