Help identify this spring.
Old Sep 7, 2011 | 08:22 PM
jasong21's Avatar
Default Help identify this spring.
I am looking for some help. The other day I put a Transgo HD shift kit in my 4l60e. I also put a Corvette servo in it along with an aluminum 1-2 accumulator. I was just about finished when I found this half purple and half green spring on the table. It is two colors and Transgo says they use no dual colored springs. It was dry and clean so I assumed it did not come out of the tranny either nor did I remeber placing any of the springs from the tranny on the table. So can anyone help in identifying it.
Old Sep 7, 2011 | 08:23 PM
jasong21's Avatar
Picture didn't upload.
Old Sep 7, 2011 | 08:37 PM
jasong21's Avatar
Let's try it again.
Old Sep 8, 2011 | 02:50 PM
72blownvert's Avatar
That is your original spring you should have replaced that with the purple spring from your trans go kit.
Old Sep 8, 2011 | 09:24 PM
Vince B's Avatar
Moderator
You are correct. It is from the 3-2 downshift valve assembly. Your good to go!
Old Sep 8, 2011 | 09:53 PM
jasong21's Avatar
Thanks guys. I was not sure if maybe it had come out of the valve body without knowing it. Especially with this being my first time putting a kit in.
