4l80E transgo shift kit, why?
Old Sep 9, 2011 | 08:54 PM
flywheel's Avatar
Default 4l80E transgo shift kit, why?
6.0l/4l80E combo in my chevelle, it made 391hp/384fpt,tranny has 54k on it from a van.... tuner turn up the shift firmness a little bit, Why would or should I consider a shift kit? I don't really want this tranny to bang shift into each gear but shift firm on wide open runs! Advice on should I consider a kit and which one! Thanks alot..
Rick
Old Sep 10, 2011 | 07:59 AM
built408's Avatar
Direct clutch is a weak link in a stock 80e. The HD-2 kit helps fix this problem.
Old Sep 10, 2011 | 08:17 AM
Cam72aro's Avatar
transgo hd2 addresses the direct clutch hub issue. It dual feeds it to fix this problem. Its an easy install that doesn't take long.
Old Sep 10, 2011 | 09:45 AM
Detroit Gearbox's Avatar
The transgo kit allows you to increase the apply diameter of the direct clutch by using their 3 piece separator plate. This process can be completed (and improved over the transgo kit) without the kit, but the kit makes it much simpler for the do it your self/never done it before mechanic. It also allows you to tailor your shift firmness.
Your largest performance gain is going to be in a good converter.
Old Sep 10, 2011 | 10:27 AM
slow67's Avatar
Gingervitis Addict
It allows you do dual feed the directs without taking the transmission apart.
Old Sep 10, 2011 | 07:21 PM
flywheel's Avatar
Thanks alot, think I'll order a kit...Im running a yank 3200 convertor already...
Rick
