Cooler
Old Sep 11, 2011 | 12:59 AM
Paul57's Avatar
Default Cooler
I was wondering if anyone has had any results with the heat sink transmission coolers??? I have read a lot of "speculation" but no real world results. They make some that are dual pass, 30 & 36 inches long. That should help cool a lot more compared to the (original) single pass type that are 1/2 that length. Any results or info??? I was considering two of the 30"??
Old Oct 8, 2011 | 09:11 PM
81cuttysupreme's Avatar
I'm wondering the same thing
Old Oct 8, 2011 | 11:09 PM
Paul57's Avatar
I gave up on the heat sink style and went with a 2" thick plate type that had as many rows as I could fit (between the frame and body). I read that the plate type was the best which makes sense since it has the most surface area for fluid cooling. Mine had 19 plates and I got it from ebay. It is mounted on its side (for lack of a better explanation). I thought it may be a little more efficient that way since the heat gets out a little sooner.
Old Oct 9, 2011 | 07:30 PM
what is a plate type? is that like a traditional radiator style?
Old Oct 9, 2011 | 11:53 PM
Paul57's Avatar
I hope the link works. This is a plate (and fin) style.
http://cgi.ebay.com/ebaymotors/?cmd=...K%3AMEWNX%3AIT
The traditional type is considered tube and fin.
Old Oct 10, 2011 | 12:24 AM
blk99sleekbeak's Avatar
i run a tci 26000gvw in front of my radiator and an extra deep derale pan with the cooling tubes and rarely see temps above 150. This is with a rmvb th400 with a 3600 ptc converter
