Converter questions
Old Sep 12, 2011 | 10:09 PM
Krazedkuniva's Avatar
Default Converter questions
I'm pretty new to the LS1 world, and I'm wanting to get a higher stall converter for my T/A. I've searched through countless threads and I think I might have an idea of what I need, but I want to ask to be sure I'm doing everything right.
The converter I'm thinking about is a Circle D converter, somewhere around a 3600 stall. Should I go with the 245mm or 258mm, and single disk or multi disk? Current mods are in sig and I do eventually plan on doing heads and mild cam (gotta be able to pass stupid CA smog lol).
Tranny cooler.. I've read that this is highly recommended. The B&M 24k gvw cooler from TR seems to be popular. My question to those of you that have used this--does it come with all the hose and fittings you'll need, or did you have to order that separately?
Last question (I think?).. Flexplates. I see some people recommend upgrading that when they do the stall. Necessary? Recommended ones?
Thanks in advance!
Old Sep 12, 2011 | 10:45 PM
01ssreda4's Avatar
1. Go 245 single disk, 3600 would be a good speed.
2. The B+M 70264 comes with everything need for install.
3. I recommend an SFI flexplate for piece of mind. The stockers aren't the best things in the world. SFI units are available from the converter makers I'm sure, I know if you sweet talk Yank they might throw one in with an SS3600
Old Sep 12, 2011 | 11:06 PM
Awesome, thanks for the very helpful answer! I like this forum already.
Old Sep 12, 2011 | 11:12 PM
projectX's Avatar
If you have any questions about set up contact Chris @ Circle D - All our sponsors have outstanding products. Also, I've been told by many many shops and even some sponsors a flexplate with mods like ours isn't necessary but I guess for pom.
Old Sep 13, 2011 | 01:47 PM
Yeah it seems like Chris is a very helpful guy. I'll contact him before I place the order also. Thanks for the help.
Old Sep 13, 2011 | 03:16 PM
Circle-D's Avatar
Be glad to help......
Chris
Old Sep 13, 2011 | 03:43 PM
Thanks! Are your converters the same for the 4l60e and 4l65e, or are the converters different for those?
Old Sep 13, 2011 | 04:01 PM
Circle-D's Avatar
The 4L60/65/70 are the same assuming they are from a LS motor.
Chris
