When did GM start using Corvette servo in A4?
If I am off base, I would appreciate someone setting me straight.
SteveC
SteveC
Note: This servo assembly is already factory installed in C4 & C5 Corvettes and 1993 - Up LT1/LS1 equipped F-body vehicles.
SteveC
The 4L60E's in F-cars and Corvettes have had that servo since the LT1 days. The 2/4 band is applied and released by a hydraulic servo, consisting of fluid pistons and a pin to act against the band. In the "corvette" servo, the 2nd apply piston has a surface area about 35% greater than the standard version. So for the same fluid pressure applied, you get more force on the piston/pin, and therefore more clamping force on the band. You feel this as a "crisper" 1-2 shift.
SteveC
