How to change TCC lockup speed with edit
Old Mar 9, 2004 | 09:33 AM
Y2KSS's Avatar
Default How to change TCC lockup speed with edit
I was wondering how you change Torque convertor lockup speed with LS1 edit. Mine locks up way to soon around town at low RPM's and causes the car to buck some with my cam. Thanks
Old Mar 9, 2004 | 12:17 PM
JustAnotherSS's Avatar
A4 TCC Tab - Normal Mode MPH vs. %TPS:
This table consists of velocities, in MPH, at which the TCC will lock and release. It is scaled vs. gear and TPS. You should make sure that your apply values are larger than your release value. You should consider raising the release value if you raise the apply value - else you can end up with inconsistant TCC actuation. This is set when in normal shift mode
here ya go
Old Mar 9, 2004 | 12:23 PM
Y2KSS's Avatar
Thanks, I will give it a try.
