broke my th400! This normal?
Old Nov 12, 2011 | 04:45 PM
BLINGOLE's Avatar
Default broke my th400! This normal?
[IMG][/IMG]
Im glad i have a superbell setup waiting to go in it!
Still ran a 6.7 at 112 on the pass it broke
Old Nov 12, 2011 | 05:47 PM
XpEdItIoUs's Avatar
The stock bell housings on the th400 are really weak, it has to do with the casting. Good thing it broke along the edge where you cut to put a SFI bell housing on.
Old Nov 12, 2011 | 05:51 PM
MUSTANGBRKR02's Avatar
Are you running a solid trans mount or motor mounts?
Old Nov 12, 2011 | 07:42 PM
BLINGOLE's Avatar
red poly motor mounts and trans mount
Old Nov 12, 2011 | 07:48 PM
BLINGOLE's Avatar
just built a new one,, with a super bell and a 8 bolt pump.. hopefully this does the trick
Old Nov 12, 2011 | 09:57 PM
BLINGOLE's Avatar
My luck it ran a crack down the housing and brok a chunk off the pan mating surface.. its cool though I got a new one built already. It just flippedme out when I saw what happend
Old Nov 12, 2011 | 10:05 PM
tt383lt1's Avatar
you can replace the bell housing on them? how
Old Nov 12, 2011 | 10:18 PM
You did it yourself?
Old Nov 12, 2011 | 10:37 PM
1320's Avatar
you get a jw ultra bell or similar.....then hack of the belhousing part of the case.
I ve seen almost everything you can imagine to get the job done...
Old Nov 13, 2011 | 01:56 AM
BLINGOLE's Avatar
What build it? Ya man 400's are a breeze if someonewalks u threw one or two of them. I have problems with end play clearances on the clutches and input shaft whatnots. But had a case that had a damaged bell housing from a mud truck so I took a cutoff wheel and cut the rest of the housing off. Then went and got some grade a bolts to mount the bell on. I did have a 6 bolt pump in the old trans and the new one was a 8 bolt, but I just drilled new holes and made it work.
Man these trans are really easy to tear dow and rebuild as long as you have someone to call and ask a tupid question to about it.
Old Nov 13, 2011 | 01:58 AM
BLINGOLE's Avatar
Yes sir, if u notice the new bell is extra think and its sfi approved. In case is the flywheel breaks it won't get your legs. The new bell bolts to the pump.
Old Nov 13, 2011 | 08:50 AM
Damn good job. I was going to rebuild my 400 when the clutches went but my builder only charges 250 for labor so to me that's worth the price of aggravation lol. But I may try one.
Old Nov 18, 2011 | 10:12 PM
fastsspr's Avatar
Is hard to cut the bellhousing to use one sfi approved?
Old Nov 18, 2011 | 10:55 PM
XpEdItIoUs's Avatar
Not really i laid mine on a spare wheel and used a saw zall and cut it when i rebuilt my tranny.
Old Nov 18, 2011 | 11:54 PM
BLINGOLE's Avatar
Did you have to trim yoursuperbell to clear your flexplte/flywheel?
Old Nov 19, 2011 | 12:43 AM
XpEdItIoUs's Avatar
Mines the JW ultrabell no trimming had to be done
Old Nov 19, 2011 | 06:19 PM
Any problems with it clearing the tunnel?
Old Nov 19, 2011 | 08:25 PM
XpEdItIoUs's Avatar
None.
Old Nov 19, 2011 | 10:19 PM
Detroit Gearbox's Avatar
blingole, usually a bad vibration (flywheel/drive shaft) causes breakage like that.
Either that or improper drive shaft length or to much flex in your chassis. A solid mount with a twisting chassis will do it.
As far as the strength of a stock bell housing goes, its not the cause of your problem.
The hub on your converter will most likely have excessive run out from your failure.
Have it checked.
Old Nov 21, 2011 | 05:24 PM
BLINGOLE's Avatar
Have it checked.
i already reinstalled it and it seems to be fine. I actually ran the best time ever with it since then. But honestly, ive had some "issues" with the company i bought the convertor from and i feel like i should send it to FTI to be looked over.
Now after what you just mentioned i think your right. Ill have it checked soon.
