early vs late 4l80e
Old Nov 16, 2011 | 09:14 AM
383lt1impala's Avatar
Default early vs late 4l80e
Hello I recently swapped in a 80e in my m715 with a 6.5 diesel. And I have a trans controller and harness from a 93 6.5 diesel truck with a 80e. And it shifts fine into reverse, 2nd and 3rd but it does not want to shift into 4th at all. I have a rosler back box in it right now and 4th works good. So if there something different in the wiring? Maybe the od pin is else ware idk. I know the 93 truck takes a 80e with the cooler lines that are close to each other like a 60e but the one I have right now has them separate its from a 99 hummer. Well thanks in advance.
Old Nov 17, 2011 | 06:40 AM
forcd ind's Avatar
right around 93 they changed the case plug-cant remember if it was a 92-93 change, but im sure if the black box plugged in, you have the latter plug
i thought they also changed the force motor, used a diff voltage around then
Old Nov 17, 2011 | 08:34 AM
slow67's Avatar
Gingervitis Addict
If you have the updated harness (93-03 harness) its the same EPC (even if the GM did change the frequency). 04 is a differnent harness/EPC.
Old Nov 18, 2011 | 09:26 PM
evo462's Avatar
I have a 93 4L80e and it had the older style plug. I had to order a new harness/plug for it when I had it rebuilt.
