Stuck input drum 4l60e
Old Nov 16, 2011 | 07:36 PM
teejayr's Avatar
Unhappy Stuck input drum 4l60e
Can't remove input drum from transmissions. I have read a few threads but nothing has worked. I yanked and rotated, even put the bell housing back on and tryed dropping it on cardboard. it seems that I may have moved it up some after hours of yanking but I am not positive. Any suggestions? I'm thinking about ordering a used one on ebay, just have to get this bugger out.
Thanks,
TJ
Old Nov 16, 2011 | 11:52 PM
traenknerperformance's Avatar
the input housing or the reverse input drum?
Old Nov 17, 2011 | 03:57 AM
teejayr's Avatar
The input housing. Reverse input came out easy. I think the 3-4 clutches are bad.
Thanks.
Old Nov 17, 2011 | 05:15 PM
bigmac108's Avatar
It sounds like the 3/4 clutches ate the outside planet that they sit on. Wow thats not good cause theres a small snap ring in the center that holds the output shaft in. I have no ideas. I would be trying the same thing you are doing! Good luck
Old Nov 17, 2011 | 06:47 PM
67RSCamaroVette's Avatar
Did you remove the small snap ring around the shaft at the bottom of the clutch pack? It's usually yellow
Old Nov 27, 2011 | 06:15 PM
teejayr's Avatar
UPDATE
Left the transmission upside down with the bell-housing facing the ground over night. Next day i picked it up and on first drop came right out. 3-4 clutches were fried (spacers wore out?)
Im going to order 5 clips with that 10 springs since they are all different sizes.
Does anyone prefer soaking the clutches or installing dry and letting it naturally lube itself?
Thanks for the help
Old Nov 28, 2011 | 05:35 AM
Vince B's Avatar
Moderator
Soaking clutches for at least 10 minutes is always a good idea once you get your clutch clearance set.
