4l60 dipstick install.... help
Old Nov 28, 2011 | 02:52 PM
glarior's Avatar
Default 4l60 dipstick install.... help
I bought a flexable dipstick for my 4l60 into a 80. I removed the incorrect on the shop installed and put in the correct one. The problem is I can't get the dipstick tube to seat all the way in the trans. It is in a very tight spot and I can't get leverage to seat it with the car on stands. Any ideas on how to seat it all the way? Tricks? anything so I can finish that part of the project..
thanks
Old Nov 30, 2011 | 12:31 AM
soundengineer's Avatar
can you take a picture to show what you are talking about?
I have a trans that is a 4l80 case and I have plenty of room to get in there...
maybe just a coat hanger that you can wrap around the dipstick, pull straight down to seat it, and then bend the hanger to get it off the dipstick..
Old Nov 30, 2011 | 03:41 PM
DopeFedZ's Avatar
I installed a madman tube one on my 4l80. I used a little wd40 on the tube to get it seat all the way. It was having a hard time sliding all the way into the little rubber grommet/seal.
Old May 21, 2013 | 10:54 PM
Possum Boggs's Avatar
im having the same issue as we speak!
Old May 21, 2013 | 10:56 PM
greenvortec97's Avatar
coat hanger, swearing, channel locks, having a second person from the engine bay twist left to right while you try to push the tube down into the grommet. All these have worked fine for me
