Auto conversion what Transmission cooling??
Old Dec 8, 2011 | 12:03 PM
baezi z06's Avatar
Default Auto conversion what Transmission cooling??
Hi guys
i have a C5 Vette 6speed 500+ rwhp + 200-300 shot spray
i´m going Auto and i´m thinking what best solution in cooling the trans
i want a good cooling and best for the budget
what´s recomended do i need to get a Auto radiator or just tranmission cooler in front
thanks
Baezi
Old Dec 9, 2011 | 08:47 PM
ROMERO98Z28's Avatar
am trying to do the same thing +1
Old Dec 10, 2011 | 12:57 PM
RARON455's Avatar
I swapped from a sixspeed to a 4l80 from jakes, I am still running my 6speed radiator, and a cooler in front of it,, My trans temps are low, My gauge shows around 160-180 depending, so that tells me my cooler is doing a good job. I wouldnt trust a stock radiator to take care of my High $ performance trans setup anyway. Hope this helps.
Old Dec 27, 2011 | 05:56 PM
baezi z06's Avatar
Can i use the A/C console , i have already deleted the A/C in my car.
Baezi
Old Feb 3, 2012 | 07:07 AM
baezi z06's Avatar
how big is you cooler ?
If i go to standalone Transmission cooler and stick whith the manual radiator how big needs the cooler to be.
should i go whith two one big and one small
What about lines, : use the stock´s or get bigger better flowing lines , what´s recomended
i have 3800 stall and non lock up converter
thanks
Baezi
