4l60e transgo shift kit?
http://www.sonnax.com/product-lines/.../filter?filter[make]=1&filter[unit]=243
Could you please give us a link to your recommended "servo release valve". Thanks.
http://www.transmissioncenter.net/PinHole.htm
Am I correct that the Sonnax "hp kit" augments the Transgo HD2 kit, perhaps with some overlap, or would you just install the Sonnax kit and skip the Transgo kit?
I plan to immediately order exactly what you recommend and experiment with it.
http://www.sonnax.com/system/announcement/77722-01K.pdf
It claims to be an improvement on even the GM dual-spring. It is also listed for even the 4L65E, which didn't come out until 2002.
Having read the full instructions on the Sonnax kit, I still like the Transgo HD2 kit, especially for its $78 price on Summit. (The Sonnax kit is twice the price.) Since I already have the HD2 kit installed on my 2010 4L65e (with new 2006 valve body), I plan to add the following Sonnax parts:
77701-076 - The 2-3 shift check valve you recommended
77754-41 - An improved 2-3 shift valve (very interesting!)
77722-01K - The high RPM spring
77749-02K - A sun shell with unique thrust bearing
Obviously the later two parts require disassembly of the trans.
IMO it only makes sense to install a (any) shift kit into a new-ish or overhauled transmission. Simply installing it on a well-worn 100,000+ trans is probably not a good idea. Some of the Sonnax parts are to repair worn parts, but that is really just part of the overhaul process.
(I hope no one feels that I am hijacking this thread; I am trying to stay on topic.)
Rebuilt one at trade school but weren't really shown properly and never wanted to touch an auto after that, but after going to a new dealership were we rebuild gearboxes in house and being sent to a training course were was shown properly i'm more keen to have a go at rebuilding myself.
Would these handle a 600-700 hp motor and the odd 7000-7200rpm shift along with daily driving(would be tuned with motor properly when new engine tuned)? and which kits are best to get?
Some vendors claim to build 600+ HP 4L65E transmissions and the sponsors here probably do use the best parts and techniques possible. But I doubt they would last tens of thousands of miles and hundreds of track runs behind a true 600HP engine with slicks.
Read what one sponsor here promoting 4L80's says on their site:
http://www.jakesperformance.com/4L80E.html
I am considering one of the sponsor's 4L65E for my 500HP LS2, but if I go to any forced induction, I will first switch to a 4L80E.
Again, just my opinion.
If you have a choice of 4L60E, picker a later year, especially 2002 or later. Otherwise a rebuild with an upgraded Sun Shell (e.g. Sonnax or "The Beast") is recommended. GM made quite a few improvements in 2002. A 4L65E is better yet as it has 5-gear planetaries and a stronger 3-4 clutch pack.
In the tune you can set a "pressure value" between 0 and 96. "0" really gives you 75psi and "96" really gives you 235psi.
Last edited by mrvedit; Feb 16, 2015 at 07:26 PM. Reason: Minor technical correction
