Need help
Old Dec 22, 2011 | 10:25 AM
superLS1camaro's Avatar
Default Need help
Will 4l60 and converter from 94 lt1 . Work on my 2005 5.3 . I'm puting it in my 88 monte Carlo thanks
Old Dec 22, 2011 | 10:40 AM
performabuilt's Avatar
LS1Tech Sponsor
You can do it you will need the collar bushing like is use with the 350 and 400 swap that goes in back of crank and you will have to enlongate bolt hole in flexplate and change out the wiring harness to allow use of the later 3-2 solenoid. You best bet is to get the correct trans for the engine combo
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 22, 2011 | 01:52 PM
I know for 125 u can buy flex plate and bushing and bolt to bolt the th350.i have a good 4 l 60 and converter that's why I was asking. thanks Alot
Old Dec 22, 2011 | 01:54 PM
I have a guy that can wire up the tranny . I just want to know what I have to buy to make this work
Old Dec 22, 2011 | 02:25 PM
LS1Tech Sponsor
As far as bolting up you just need the samepeices you just mentioned to bolt up a 350 or 400
__________________
Call 888-744-6542
Old Dec 22, 2011 | 08:55 PM
thanks for your help
