th350 cruise control
Old Jan 3, 2012 | 03:57 PM
chad rock's Avatar
Default th350 cruise control
Cruise won't work I have th 350 abs mod for speedometer my 99 trans am has a 9 inch ford with no wss on rear .the car had 3 channel brakes .the abs inop light stays on now. MY friend said cruise won't work with this light on. What can I do to fix this ?
Old Jan 3, 2012 | 04:34 PM
slow67's Avatar
Gingervitis Addict
You have the ABS signal going to the PCM for a speedo? I had 3 channel brakes, went to a 9 inch (no more ABS), my cruise still works.
Old Jan 3, 2012 | 05:03 PM
chad rock's Avatar
Yes front wheel speed sensor is used for signal to pcm .
Old Jan 3, 2012 | 08:37 PM
Fbodyjunkie06's Avatar
That's how my last car as rigged up, I didn't do the mod myself, but my cruise didn't work then again I had a full manual valve body. I'd like to do the abs mod to this one I have now as the speedo doesn't work.
Old Jan 4, 2012 | 01:00 PM
chad rock's Avatar
I have full manual valve body as well .just be nice to have cruise when I get out oninterstate
