th400 to 4l80e
Old Jan 9, 2012 | 01:44 PM
dkbmxer002's Avatar
Default th400 to 4l80e
i see a lot of info on one and the other but not much on going from th400 to 4l80e...
what all can i use from my current th400 setup if i decide to go 4l80e? i know the shifter obviously will have to be changed back to stock or something else. i know the converter needs to be changed..
will the driveshaft work? will the trans brace/mount work? dipstick? anything else i might be missing?
Old Jan 9, 2012 | 03:27 PM
soundengineer's Avatar
whatever shifter you have will work with a change of gates..
or you may just want to put in a different shifter if your current one does not have interchangeable gates on it.
you will need a different driveshaft and trans crossmember..not sure about the dipstick...
need a different converter as well.. different front plate, different pilot.
Old Jan 9, 2012 | 04:13 PM
dkbmxer002's Avatar
i have a cheeta shifter now.
Old Jan 9, 2012 | 06:27 PM
kjhallex's Avatar
About time you get smart! lol how's it going?
Old Jan 9, 2012 | 06:43 PM
Cam72aro's Avatar
Look for my thread 4l80 on the cheapo. No on the cross member, no on the driveshaft, maybe on the shifter, maybe on the dipstick.
Old Jan 9, 2012 | 07:38 PM
dkbmxer002's Avatar
Pm me info! I'm on my iPhone right now
Old Jan 9, 2012 | 08:05 PM
Cam72aro's Avatar
Couple threads above. Check it out.
Old Jan 10, 2012 | 08:46 AM
dkbmxer002's Avatar
good haha, working a lot. i'm still debating it. might just get my th400 rebuilt by a friend for now then save up for the 4l80e.
