would 4l60e tcc lockup wired wrong do this?
Old Jan 12, 2012 | 12:56 PM
s10pro's Avatar
Default would 4l60e tcc lockup wired wrong do this?
1968 camaro stock ls6 zo6 motor and 4l60 with yank 3600 red line clutches and beast sun shell , ssp wiring harness ecm is a blue and red connector, just got the car together and brought to tuner to find out car had no speed signal wire , he moved a few pins and got the signal, now trans will start in 1st for fist time and then shift second then it goes almost into limp mode nothing. then u come to stop and even if you put it into 1st it feels like starting in second or third. No codes tuner thinks clutches or wiring, any help please
''Update'' fig out buddy just wired tcc lockup wire right to my stock 68 camaro brake switch .so when brake pedal is pressed it send power to wire thinking that is what is putting trans in limp mode. info please if this could or could not be my prob. going to get a relay today.
Old Jan 12, 2012 | 07:30 PM
mrvedit's Avatar
Moderator
Is this a 4L60E controlled by the PCM, or is this an ancient old 4L60 controlled by a governor? I assume you meant to say it is a 4L60E. In that case the PCM controls the TCC and you must make sure the trans cable is correctly wired to the PCM and remove the crazy wire to the brake switch.
Old Jan 12, 2012 | 10:47 PM
lt1-xjs's Avatar
All the 700r4, 4l60 or 4l60e TCC are controlled by the pcm, to tell them when to lockup. They are all wired through the brake switch to interrupt or unlock the TCC.
Old Jan 13, 2012 | 09:35 AM
mrvedit's Avatar
Moderator
I understand what you are saying, but "Wired through the brake switch" might confuse someone. Only the PCM is wired to the TCC; the brake switch sends a signal to the PCM, but there is no direct wiring.
As I read S10PRO's post, someone did wire the TCC directly to the brake switch, which would be a dangerous hack.
Old Jan 13, 2012 | 12:33 PM
lt1-xjs's Avatar
The pcm feed wire is wired directly to the brake switch, otherwise there would be no signal.
Old Jan 17, 2012 | 09:36 AM
s10pro's Avatar
prob fixed , on older car when you press brake pedal just sends power to lights put a relay in car works mint.
