6 speed to th350
Old Jan 15, 2012 | 06:48 PM
ccd_1606's Avatar
Default 6 speed to th350
I'm looking at swapping my 6 speed for a turbo 350, can anyone give me any insights on how complicates this is going to be? Or maybe a thread where someone else has done it.
Old Jan 16, 2012 | 02:56 PM
fastsspr's Avatar
I think is info abut it in the stickys ,is the swap when you go th400 !
Old Jan 18, 2012 | 07:20 AM
Justins00ss's Avatar
Yeah just did the m6 to th350 over the summer. Not too complicated. I used a bmr crossmember, fti specific tq converter, tci flexplate, b/m stealth pro ratchet shifter, madman dipstick and a b/m tranny cooler with push lock hose.
The only issue I ran into was having my driverside o2 sensor moved due to it interfearing with the linkage. Other than that it bolted right up and wiring in the reverse lights and neutral safety switch was easy.
