Converter efficiency from a roll?
Old Feb 29, 2012 | 09:08 PM
wav3form's Avatar
Originally Posted by sabersaw30
Ended up getting one from greg at fti.3600 with 1.78str Wanted a good roll car.Can't wait to put it in.Should be very efficient.Don't do drags to much.Props to fti great costumer service.Ordered mon. And got here today.Wow
Let us know how you like it once you get it installed. I want to set my A4 up for rolls too since I don't go to the track and I'm mostly highway driving and like having a bit of fun now and then. I'm actually happy with how it is stock... 3.23 gears, stock TC but I know it can be so much better.
Old Mar 1, 2012 | 11:01 PM
RevGTO's Avatar
Pontiacerator
A good converter is advantageous in all conditions. Another reason is that a typical 9.5" converter is almost 20 lbs. lighter than the stock behemoth. The higher stall speed keeps your motor in the meat of the torque band and it's fighting less inertia as well.
Old Mar 2, 2012 | 02:07 PM
sabersaw30's Avatar
Op here is some excellent info i found.http://www.ls1gto.com/forums/showthread.php?t=349786Got to be the best information out there.
