02 LQ4 and 98 4l80e What Do I Need?
Old 01-28-2012, 08:57 PM
86SS86LS's Avatar
Default 02 LQ4 and 98 4l80e What Do I Need?
I plan on swapping an 02 LQ4 and 4l80e out of a 98 chevy truck into an 86 Monte SS. The 4l80e was behind a 350 and the torque converter is included. The LQ4 does not have a flex plate.
What I need to know: Will a 4l80e torque converter that was used with a gen1 350 bolt up to an LQ4 flex plate? Or do I need a different torque converter? And I would assume that I need to buy the LQ4 flex plate WITH the crank spacer?
Old 01-29-2012, 07:10 AM
forcd ind's Avatar
as long as you use the 4L80E spacer/flywheel it will bolt up
Quick Reply: 02 LQ4 and 98 4l80e What Do I Need?
