Switching from a 60E to new 6 speed auto
It 's this or a new carrier and gear set, maybe a spool.
That is assuming you already running a Gen IV motor.
I miss my stock 3.42's for N20 passes.
I understand that you should cross the traps in your 1-1 gear, be it 2nd , 3rd 4th or even 5th. What I'm looking at is with 4 gears before the 1-1 how much further down the track will I be. With a higher 1st gear it will be easier to launch, allow the car to stay in the power band on the 1-2 shift etc.
We would also like to go back to the TX mile. The set up now runs out of gear to soon.
The 80E does look like the best option. The TCI 6x is based off it.
i know on my new truck with the GM 6 sp, in manuel mod you can shift it man., but its not a full man like your used to (if you got loose and peddaled it, it would change gears downard and back up to the highest gear selected)
Twist Machine has a steering wheel mount paddle, but $$$$$$$$$$$$$$$
http://www.race-mart.com/TCI-TCI-611623.html
