InstallUniversity TH400 conversion from M6: Follow along
Old Apr 28, 2017 | 10:20 AM
  #61
wizkid's Avatar
Install Director
Here is a photo of the trans cooler mounted. This is looking under the car up past the air dam. I made the sheet metal brackets that hold the cooler.
Trans Cooler TH400
Old Mar 30, 2018 | 09:23 AM
  #62
Game ova's Avatar
Trans Cooler TH400
This has to be the longest th400 swap of all time. Your tenacity is to be admired.
Old Mar 30, 2018 | 10:41 AM
  #63
wizkid's Avatar
Install Director
Old Mar 30, 2018 | 08:36 PM
  #64
Jfab's Avatar
Did you have to add shims to your transmission mount?
I am installing th400 as well and I have a two inch gap from where the bottom of the mount is and the cross member. i bought a midwest chassis crossmember but i am not sure it will work. Might just make my own.
Old May 25, 2021 | 02:53 PM
  #65
wizkid's Avatar
Install Director
I do not believe so. I will look next time I am under it. You can see the trans mount page here with photos http://installuniversity.com/ls1/ins...unt/index.html
