feels like no first gear please help.
Old Feb 19, 2012 | 06:38 PM
Pjizle's Avatar
Default feels like no first gear please help.
Hello I'm a newbe to the forum and was looking for some help. I own a 02 z28 auto and when I pull off from a stop its real slow @ first but then catches speed as if I was leaving in 2nd. I took it to the trans shop and was told it was fine internally but it has a power delivery issue. Does anybody have any idea what the problem could be and a way to fix?
Old Feb 19, 2012 | 07:04 PM
Gilbert@Ace Racing's Avatar
It is possible that it is in limp mode which will cause it to launch in 2nd. Did they tell you if it had any trouble codes? Did they tell you that it has no voltage or the engine is down on power?
g
Old Feb 19, 2012 | 08:09 PM
Pjizle's Avatar
Said it wasn't getting enough voltage.
