4l80e rear speed sensor signal needed to build DIY cable-x.
I've done some searches, but not found what I'm looking for.
What signal does the rear speed sensor produce on a 4l80e? I know it is suppose to be 40 pulses per rotation but that is the amplitude of the signal and also the the shape of the wave? I suspect it is a sign wave... 12V or 5V?
I'm looking at a little project to run my old mechanical speedo of the rear speed sensor of the 4l80 and drive a dc motor to run the speedo.
I need to find the correct DC motor... Have a couple that look promising on paper but real world test will tell the tail. I already have the code prototyped for the microcontroller and PWM motor speed controller so about 1/2 way there, just need to the signal from the tranz into the board and it looks like a cheap viable solution.
I can always use the micocontroller for other fun projects if this does not work out.
If this works well I think I can also incorporate a data logger... but time will tell, possibly also take an input for the tach signal also.
Thanks,
Bruce
Thanks,
Bruce
