4l60e removal
Old Feb 27, 2012 | 01:19 PM
bstuby's Avatar
Default 4l60e removal
Got all the bolts out I think. How many are there exactly? I can't get the damn thing to slide back at all. I'm afraid to pry on it at all because I don't want to crack anything. What does everybody pry on to get it out and how much pressure does it take? I was under the impression that there were 8 bolts, but I only have 7. There suppose to be one at the 12 o,clock position, but there isn't on mine which leads me to believe that it's been out before at sometime. It just feels like it's stuck. I been out there shaking the **** out of it trying to get it to break loose.
Any advice?
Old Feb 27, 2012 | 02:04 PM
Kingc8r's Avatar
Wiggle it back and forth. Probably caught on the dowel. They probably didn't put that bolt back in if they serviced it.
Old Feb 27, 2012 | 02:14 PM
bstuby's Avatar
I'm wore out from trying to wiggle it back and forth. I was gently prying on it, but it just doesn't want to move. I sprayed down the dowels with some penetrating oil. I will see if that helps at all.
Old Feb 27, 2012 | 03:09 PM
Kingc8r's Avatar
Yea mine took quite a bit of shaking/prying.
Old Feb 27, 2012 | 04:40 PM
bjamick's Avatar
Jack it up on the pan, make sure you have a board or something to protect the pan. Just start slowly, jack it up a bit, then wiggle, jack it up more and wiggle. I pryed against the block. Just use common sense if you feel you are going to crack something. It's just stuck on the dowels. Make sure you have the dip stick and coolant lines removed to.
Old Feb 27, 2012 | 07:29 PM
bstuby's Avatar
No luck, I borrowed a map gas torch and I'm going to try heating up the case around the dowels a little and see if that helps at all. If not it's going to the shop. I'm tired of laying under this damn car.
Old Feb 28, 2012 | 02:02 AM
lncboytre_d's Avatar
LOL, I feel your pain, I just went through the same thing yesterday. My back, shoulders, and triceps are killing me. Take your hand and run it behind the intake....follow the firewall, make sure that last bolt is not still in there. From there use the two jacks as stated. Be paitent young warrior.
Old Feb 28, 2012 | 11:41 AM
bstuby's Avatar
I finally got it. Patients got me NOWHERE.. I had to get get down right brutal with that bitch. 3ft prybar with a gorilla grip on it, and a map gas torch. What a pita!
Old Feb 28, 2012 | 11:42 AM
bstuby's Avatar
Now hopefully I can get it back in...
Old Feb 28, 2012 | 04:04 PM
bstuby's Avatar
Are the flexplate bolts tty? I just bought a new flexplate and was wondering if I should buy bolts also?
Old Feb 28, 2012 | 04:17 PM
You can reuse them. Glad you got it out, the install is a lot easier with someone helping. You can do it solo, it just takes alot more work.
Old Feb 28, 2012 | 05:05 PM
mrvedit's Avatar
Moderator
Thoroughly clean the dowels and the dowel holes. Due to the different metals (Aluminum case with steel dowels) and exposure to moisture, you probably had some corrosion that kinda welded the parts together. The dowel should be snug, but don't need to be super tight.
Old Feb 28, 2012 | 07:55 PM
bstuby's Avatar
I planned on cleaning the dowels. I'm going to be doing the install myself. I took it out by myself, I can put it in myself righ... does it matter if the dowels came out with the trans? I thought they were suppose to stay in the block?
Old Feb 28, 2012 | 09:37 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
when my dowels came out with the tranny,I pushed/punched them out the tranny,cleaned them up with a wire wheel,and put them back in the block.
Old Feb 28, 2012 | 09:54 PM
bstuby's Avatar
Gotcha..
