Neutral safety switch
Old Mar 6, 2012 | 02:25 PM
kosimoto's Avatar
Default Neutral safety switch
I have been searching for this info and I found it, but I forgot the info like a dork and now I can't find it. What color are the wires that I need to hook up to my safety switch on my shifter? Thanks
Old Mar 17, 2012 | 12:11 PM
kosimoto's Avatar
Bueller?
Old Mar 18, 2012 | 07:52 PM
kosimoto's Avatar
Really!
Old Mar 19, 2012 | 03:54 PM
midwestjunk's Avatar
I just swapped a 6 speed to th400 in my car. The clutch switch under the pedal has a green wire and a purple wire. Cut those and run them to ur shifter. If ur an a4 car I have no clue
Old Mar 25, 2012 | 03:58 PM
kosimoto's Avatar
Thanks and I think your right. Somebody else said dark green and purple too.
Old Mar 28, 2012 | 10:48 AM
runtwrestlin's Avatar
Yes, the Purple wire with the white strip goes to the 15A STRTR fuse, and the Dark Green wire goes to the starter relay.
If it's an auto (which I don't think it is judging by your response) it's pins E and F of the Park/Neutral Position switch.
