convertor size?
This is the cam to stall to diff setup they recommended for it (well cam i already had).
Cam: 235/243 .621/.624 113 lsa comp cam (already have).
Stall: 3,200 non lockup (will be 98% street driven 2-3 track hit outs if that a year).
Diff: 3.73 gears.
Does this stall sound good for the engine/cam and diff?
as said will be 98% street driven, not a daily but will mainly be driven on the streets on weekends with the odd freeway cruising and with the odd track hit out every now and then, also may see a 100-250hp nos set up so will probably get a stall to take this hit.
Are there any other stall sizes that people would think will work well with this setup and brands that are good?
Also what brands are good for light weight flex plates? or will factory be ok?(factory flexplate balance was checked when bottom end balanced)
That'll raise your cruising/freeway rpm and lower your gas mileage.
Typically,3500-4000 lockup stalls are recommended by most enthusiasts.
I think they recomended a non lock up cause it will see a lot more round the streetsduty like 60/70 and 80km/h aread than 100km/h freeway driving. Nearly all the roads around me are max 80km/h.
Chris
