Pulling trans with solid motor mounts.
Old Mar 8, 2012 | 06:20 PM
sabersaw30's Avatar
Default Pulling trans with solid motor mounts.
I bought me a converter.Will the trans drop down far enough to get the bellhousing bolts out with solid motor mounts?Are will i have to pull the intake?Please tell me i dont have to pull intake.
Old Mar 8, 2012 | 10:08 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
If they are Spohn mounts it won't drop down enough
Old Mar 8, 2012 | 10:20 PM
joecar's Avatar
On an F-car...? You don't have to remove the intake, but unclipping/unhooking the air lid would help.
Old Mar 8, 2012 | 10:48 PM
01ssreda4's Avatar
With solid motor mounts the motor won't drop at all. I would not recommend forcing it either. You need to drop the k member 6-8 inches to gain clearance to clearly get to the bellhousing bolts.
Old Mar 9, 2012 | 04:03 AM
sabersaw30's Avatar
Okay i may just loosen my motor mounts and see if i can drop the motor enough.Thanx for the options.
Old Mar 9, 2012 | 05:41 AM
01ssreda4's Avatar
Loosening the bolts will not work either. Been there, done that. To drop the k, take the sway bar, front shocks, and steering shaft loose and support the body. K will drop with 6 bolts.
Old Mar 9, 2012 | 02:00 PM
sabersaw30's Avatar
Okay thanx.
Old Mar 10, 2012 | 07:22 AM
soundengineer's Avatar
You just need to drop the k member bolts enough to let it tilt.
Then you can get at it with a few extensions and a wobble...
I've had mine in and out a few times with no issues.
Old Mar 10, 2012 | 07:32 AM
MUSTANGBRKR02's Avatar
I find it easier to remove the intake to get to them.
Old Mar 12, 2012 | 07:48 AM
Golf&GM's Avatar
I haven't tried removing the intake, but dropping the k-member some isn't too tough, it's just loosening some easily accessible bolts. I tried loosening the bolts on the motor mounts and when that didn't work I loosened the pedistal mounts. Didn't get me anywhere. Soon as I dropped the k-member a few inches I was golden.
