How do you hook up 2 trans coolers?
Anyone have any experience with this?
Alex
Put them in parallel.. split the line into two, run each line into a cooler then out and into another splitter (2 into 1) then into the tranny... the efficiency/load of each cooler is equal instead of the first cooler doing all the work and the second one doing very little... Series setup should only be used when using the factory system along with a supplementary cooler... recommend getting a supplementary cooler... ive got a hayden on mine...
Just get one good one thats all you need.
Parallel vs Series...Iv done both. I was told by the sponsor that wrote that sticky that it would be fine to run 2 external coolers in parallel just as long as the stock cooler wasnt hooked up. I guess they wrote that sticky just in case someone wanted to run 3 coolers. Just passing the info to you.
there are two types of coolers.. tube and fin (conventional) and plate and fin (slightly more effecient)... Brand is pretty much irrelevant, they all perform the same as far as youre concerned... The plate and fin are a bit more effecient because they cover more surface area and therefore dissipate more heat... if youre looking for the best, go plate and fin like the fluidyne one.... imo thats the best you can get... personally, i have the tube and fin Hayden cooler cause it was 1/2 the price of the fluidyne one... its up to you man...
plate and fin
Tube and fin
