What length driveshaft do I need? Short tail th350
I'm swapping a short tail th350 into my 02 and my factory driveshaft looks about 4-5 inches too short. Does anyone know the exact length driveshaft I will need? I have a stock rear if that matters. Thanks
Its always best to measure to be sure its the correct length for your car, there are some variables that can make it different. Slide the yoke all the way in the trans as far as it will go then go out 1in., thats where you want the yoke to sit. Measure the distance from the center of both u joints, that will be the length for your driveshaft.
