Huron Speed Converter before/after RESULTS thread
*All converters will have BILLET covers, BILLET lock-up pistons, furnace brazed and tig welded fins, and balloon plates.
Huron Speed C1 Torque Converter
This converter is good for those cars that are stock, bolt-ons, cam only, NA applications, or even small nitrous use.
This converter is good up to 750 hp
Good for smaller nitrous use up to 4000 stall speed.
If you would like WOT lock-up, we highly recommend the C1.3 with the triple lock up discs
-Billet Cover, Billet Lock-up Piston
-9.5" Converter
-Standard is a single disc, triple disk is also available (WOT lock-up) (C2.3)
-All converters will have a BILLET cover, BILLET lock-up pistons, furnace brazed and tig welded fins, and balloon plates
Huron Speed C2 Torque Converter
This converter is good for those cars that are Boosted (Supercharged or Turbo) as well as higher Nitrous use.
This converter is good up to 1250 hp
If you would like WOT lock-up, we highly recommend the C2.3 with the triple lock up discs
-10.5" Converter
-Standard is a single disc, triple disk is also available (WOT lock-up) (C1.3)
For most street/street applications, from stock to bolt on to head/cam combos, a 9.5", single disc converter will fill your needs perfectly. Up to a 4000 stall speed in this form will retain your towing capabilities as well for the TBSS and great drivability! If you are a power adder truck, or a heavier duty application, please contact us for a recommendation to a larger sized converter or possibly a triple disc option for your needs!
We can offer your desired Stall Speed rating from 3000 on up!
We can offer 9.5"-10.5" sizes as well depending on your power needs, as well as either single or triple disc lock-ups!
These converters will come with Huron Speed engraved on them along with a serial number so we can always identify the unit should you ever want to sell down the road!
These converters all feature a 3 year warranty!
The results:
With just the addition of the T1 3600 converter in our 2007 AWD TBSS, we saws gains of:
ET: .65
MPH: 1.2
60': .30
Also be sure to check us out on Facebook and "Like" us to keep in touch with all our current specials as well as our constant new product updates!
Click here to check us out!
www.facebook.com/HuronSpeed
Billet Cover, Huron Speed engraved!
Billet lock-up piston back side!
Front of lock-up piston, 1.5" wide, .070 thick material!
Hardened 4140 Chromoly Pump Hub and Turbine Hub!
Dual fin braced turbine!
Comparison to a typical single fin braced turbine from the competitors!
The Vehicle:
2007 Trailblazer SS AWD. 3SS model, 100% stock
+Only added the T1 3600 Converter for the after, that's it!
The BEFORE results:
100% bone stock
Average Times:
14.15 @ 98.41, 2.19 60'
The AFTER results:
100% bone stock + converter
Average Times:
13.50 @ 99.61, 1.89 60'
GAINS:
.65 in ET, 1.2 MPH, .3 60'
Before Video:
http://www.youtube.com/watch?v=P3Lkb...feature=relmfu
After Video:
http://www.youtube.com/watch?v=9VJrP...layer_embedded
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Send me a PM with what you are looking for, or for a recommendation and I can certainly get it done for you!
Jon
Thanks Mike, it will fit your application great!
Jon
