Is 4L80 worth the extra weight, or go TH400?
I will warn you though, expect to loose 5-7 tenths right off the bat just swapping to either trans. The first gear in either of them will soften up your 60' times that much. you really will looose that much, just in the first 60 feet. this is something i didn't know and found out about the hard way
and was greatly dispapointed with when i did mine.
hope this helped ya....Todd
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
There is however a cure for that now. You can actually replace the 1st/2nd gear sets and get that same gear ratio that the 4l60e had now in your th400 or 4l80e. its north of $600 just for the gear sets depending on where you get them though. this is a must though, beleave me! this is one of my next planned upgrades for sure!!!!!
They both have the same gearing 1-3. So should have almost the same effect.
I have NEVER seen anyone lose .5 tenths going to either unit.
As stated, if that occured, something was grossly wrong with the converter or the engine changed between the swap.
I would fell that going from a trans with out a transbrake to going to a trans WITH a transbrake should and will drop et's. However the 400 and 80 both have a 2.48 1st. A person can also upgrade 1st gear to I believe a 2.74 or 2.75, that along with a transbrake should be able to get you off the line.
5 tenths seems like alot, downright scary.
I've done the 2.75 gearsets in some applications. I honestly can't tell the difference usually between them and a 2.48 gearset driving around or launching. The 2.48 gearset is stronger if it's a higher HP application or very heavy.
Hello boss man, check out our H-D 4L80E!
Please contact me for a professional consultation regarding your needs. We are happy to provide you with references both here in the United States and Internationally. Be sure to check out our website at maddogtransmissions.com
Hear what our customers and fans say on our Facebook Page at www.facebook.com/maddogtransmissions
We also accept orders over the phone. Be sure to contact us and we will recommend the correct transmission for your application. For your convenience, we accept PayPal and all major credit and debit cards.
If you prefer, we can call you personally, just e-mail us your phone number.
All our transmissions are very strong and reliable, and can be used for everyday driving. Extended warranties are also available.
Thank You,
"Mad Dog" Lou
Mad Dog Transmissions
Phone 770-781-0949
Fax 770-781-0969
Web: www.maddogtransmissions.com
Facebook: www.facebook.com/maddogtransmissions
Twitter: www.twitter.com/maddoglou
YouTube: www.youtube.com/maddogtransmissions
Thank You,
"Mad Dog" Lou
Phone 770-781-0949
Fax 770-781-0969
#32
Your correct, my converter isn't quite right. I am going to be getting it loosened up and possibly restalled soon. Its a 3600 custom build ptc. its too damn tight (my fault, I asked for it that when it was a dd and street driven with plans of a turbo), and i don't see any where near 3600 fooT braking it on the motor. As I hit the kit, it zings to 3600 instantly.
When I first put this th400 in my car, it was on a stock motor, bolt ons, and same converter. I was getting at that time a 2.2 - 2.3 '60 times.
On the previous motor (same bolt ons, everything the same with the exception of the trans and new converter) with the 4l60e and a mid west 2300 stall converter, I was getting consistant 1.55-1.57 '60 foot times on nitto drag radials.
I was pretty bummed about this, and started researching to find out what was going on. Then I found out that the differences in the first gear ratios inside the two different trans. I went from a 3.06 first in the 4l60e, to a 2.48 fIrst in the th400. Again, at the time, all i did was swap the trans and converter. I have been told that restalling the converter would get me some of it back, but not all of it! that that first gear was doing just as much, if not the most damage to my '60 times. Guess I will never know for sure, cause that motor combo is long gone, the current one is on its way out the door, and a new is in the works. Plus I am going to be getting that new 2.97/1,57 first and second ger set up for the trans as well as have the converter loosened up for sure, possibly restalled too. Going to depend on the new cam, power range and all that. Once I know that, I will be having to converter matched to it this time![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
But the bottom line is, even if you put a th400 in your car, and get the converter working good and don't loose anything, your still leaving alot on the table when you compare the two different ratios. If your cars suspension and tire combo can handle it, your giving up alot by not upgrading to that 2.75 or 2.97 first gear.
I'm already taching 3k at 70mph with 3.23's. I don't want to put 3.73's or 4.10's in my car. Not interested in the extra wieght of 4l80e, or the awkwordness of a gvu either. originally, i wanted 4.10's and a gvu. But its too damn expensive, and adds to much wieght and complicates **** too damn much. The best fix for my problem, is the upraded first gear set. I get to save some money, space and weight undr the car, don't have spend money on the trans and the rear, keep my car cruising 3k or less at 70mph, and so on...I have looked at every angle, and thought out my plan of attack for rectifying the problem.
Just expect to loose something down low, or at the least know that your leaving a little on the table even if you get it right and working for you. Should have said it that way the first time, lol![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
and by the way, a TH400, and the 4L80E, both have the same 2.48 first gear in them. Here is a link on trans ratioshttp://www.oldengine.org/unfaq/leadfoot/trans.htm
#33
I know in the long run I need to upgrade. Hell, right now I'am pushing the limits of my 4L60. But I 'am really stuck on which direction. The TH400 is awesome for me because my ride is a street/strip car. And with a few ugrade and you have a 1000 hp ready tranny. But no overdrive!!! I love to drive it in the street when there is good weather. That why I keep rebuilding my 60.
My issue is the 4L80 weighs alot more then a 400.
Is a 4L80 worth it? Or should I just go with a bad *** TH400?
I have a H/C setup with 100 shot of spray, 12 bolt rear with 373 gear.
Car weights 3540 with me in it, which is why i have concerns about weight. I 'am going to add more spray and planning on a single turbo kit in the near future.
i hope this aids you in your decision
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
you cant go wrong with either or, both great trannys, but a properly built 4l80 has its perks and you can DD everywhere you go
#35
If you think a 2.75 or 2.97 ratio gearset is going to pick your car up a bunch, you are mistaken.
The really deep low gear ratios have several inherent problems. One is that most combos can't hook them. Even if you can hook the ratio, you lose the momentum on a 1-2 shift, that the converter may or may not be able to help recover, and they are weaker by design.
In SOME combos we have used a 2.75 ratio successfully to make SMALL gains. As an example I'm speaking of Stock Eliminator cars that have an underpowered (relative term) engine, with a narrow power band, big stall, and DEEP gears typically and they are looking for hundredths ET. We do it with ratios, lightened parts, lower pressures, fewer clutches, other parasitic loss improvements, etc.
In any decent combo, even the 2.48 may be too steep. Hence the 2.10 gearsets for the TH400. If your motor is making power and car isn't super heavy, the 2.48 is as much ratio as you need and maybe too much.
Look at the typical Glide with a 1.80 ratio gearset.
Just a bit of advice from someone who does it day in and day out, but the trans wasn't your ET Killer.
Converter maybe...
Engine more likely.
#36
I'm more than well aware of the ratios of the transmissions.
Converter maybe...
Engine more likely.
Converter maybe...
Engine more likely.
The conveter is bigger than the previous one on the stall. It desn't stall all the way to 3600 on the foot brake, but still hits 2200 to 2400 depending on how hot it is and how long in between rounds. That matches the previous converters stall speed that had just come out!
So now fast forward to my new motor, where I picked 2-3 tenths just swapping in the motor, but still no where near the consistent 1.57 short times I used to have.
My car is fll wieght too, by the way, hooks dead, still hooks dead. Hell, it bogs pretty bad out of the hole, but once it gets rolling, it screems;-)
The only explanation that makes any sense, is the dfference in that first gear!
#40
But either way, it stall now, exactly what used to stall on my old converter. I mean exactly! Litteraly the only difference after swapping trannies out is that damn first gear. I leave the same way, at the same stall speed, at the same wieght, on the same track, and on the same tire!
Would loosening up my converter help, yes it would, and I plan that very thing. But if car is capable of hooking with that 2.97 1st gear ratio, and I just loosen the converter up some, I will still be leaving some speed/time on the table. That is my point!
Unless you got a motor with a **** load off bottom end torque, or a loose converter that stalls in the nieghborhood of 4k (which isn't really streetable imo), your going to loose some time in the first hundred feet or so untill the motor gets wound up and the car starts moving.
Look, if all you do is swap in a th400 or 4l80e with out a gear upgrade and the same stall speed yur running now, expect your launch to soften up some. Some thing has to increase, either your trans gearing, rear end gearing, converter stall speed, low end torque, or some combo of two or more, or you launch WILL be softer! I did bsically none of that, an my experience unfortunately was the car slowing 7 tenths right out of the hole:-(
