4l60e MVB Conversion
Old May 12, 2012 | 03:35 PM
2000PewterT/A's Avatar
Default 4l60e MVB Conversion
I have searched many post and have found some good stuff but I just have a couple questions about doing a full conversion to a MVB on a 4l60e.
Will I have to install a vacuum modulator on the trans to help with light throttle shifting?
And what should be done to the computer for the tuning, will it see a problem since there will be no electronics on the trans, I can tune it out that’s not a problem but I was wondering more on the lines of what should it be set to so no problems arise with the computer. Mainly I was wondering about converter lock up or even if that will work without the computer since it is commanded by the computer.
Any extra info would be appreciated
Old May 12, 2012 | 08:29 PM
mrvedit's Avatar
Moderator
One question is why go to the trouble of a MVB?
What kind of racing are you doing? Drag, autocross, track?
Some people have misperceptions of what a 4L60E can do with proper tuning and a few mods that still leave it "automatic" most of the time.
Old May 13, 2012 | 01:20 AM
Street driving and drag racing, mostly just wanted to do it for the fun factor. I know there is no real benefit over some proper tuning and a the correct mods.
Old May 13, 2012 | 02:26 AM
ls1ya's Avatar
I wanna know to.
Old May 13, 2012 | 09:47 AM
mrvedit's Avatar
Moderator
"do it for the fun factor" is the best reason of all.
I don't have any experience with MVB, but let me start with the little bit I know (or think I know) and lets other fill in. (especially if/when I am wrong)
First, the PCM is not a huge issue. It will throw "codes", but they can be turned off. You will want your shifter to send the Park/Neutral and perhaps Reverse signal to the PCM as the internal software uses that in a variety of ways.
One issue is the EPS solenoid in the trans which increases line pressure under high throttle. I don't know if that will work correctly if the PCM doesn't know what gear the trans is in and all the codes are turned off. One solution to that is to go with a vacuum controlled throttle body; dedicated MVB probably come that way anyway. In that case, you might want to change the PCM to different OS version (also called Segment?) for a manual transmission.
IIRC, one of the trans sponsors here sells a MVB. Hopefully they will take it from here to tell you just how complex and costly this is.
Old May 13, 2012 | 09:44 PM
That was my main convern , I know some guys run vacuum modulators for the line pressure issue so ill look into that. Ill contact IIRC and see what they say, thanks for the help.
Old May 14, 2012 | 12:30 AM
mrvedit's Avatar
Moderator
Um, "IIRC" means "If I Remember Correctly". Not the name of a sponsor.
