rev limiter going into 3rd
i have the same chit.
my car won't shift into third sometime's with a 4l60e & 3000 torque converter, i alway's thought it was my opti untill i seen this thread i know it's my tranny.
I think it's that sensor on the side of the tranny because it looks like it's leaking tranny fluid from there just a little bit but enough to tell.
where can i find one at? mybe autozone or something huh.
mybe i can help you guy's by giving that sensor a try. good luck to all of us with this dam problem!
The deep pan fixed it. I made 5 runs, and each time it shifted flawlessly at ~5980 rpm. DO NOT OVERFILL YOUR TRANNY! You'll just get it foamy and it'll just start slipping more. Just get the deep pan with the extension for the pick up tube. It drops the filter and fluid pickup lower. And when you fill the fluid to the same level, it submerges the filter more. I completely agree with Jammer. I think the heavy accelleration is just pulling the fluid to the back of the pan resulting in the pickup tube sucking up air.
Try the deep pan and lemme know if it fixes it!!
To eliminate hitting my limiter I am using the factory mass air and with the Hypertech set to -6. My PCM is programmed for 6400 rpm shift points, limiter 6800.
With the bored mass air body I have been told the fluid pressure lowers, decreasing the clutch pressure. The transmission sees the correct fluid pressure only with the factory mass air body. Have not tried the bored mass air since lowering my shift with the Hypertech to -6. I plan to try the bored mass air again to see if my shift 2-3 shift increases via Auto Tap.
I feel the factory mass air could limit my hp capability. It's has an equivalent flow area of 66.2 mm. Sure prefer the 75 mm flow area but not if line pressure is decreased and causes tranny damage.
I know the Ford fluid is a bandaid fix but so far so good. The tranny has to last long even with the Ford fluid verses all the slippage I had with the Dextron III.
If we can confirm that a deeper pan is the fix then I'm going that route next.
Yup, I'm almost giddy that the pan fixed it!
