remove check ball with non lock up converter?
Should i remove the check ball in the end of the input shaft of a 700r4 when i use a non lock up converter? and do i absolutely need to replace the lock up valve with a plug? i just finished putting this transmission together and i dont want to take it apart again if i dont have to.
