4L80e HD2 Shift kit: How much power?
Old May 23, 2012 | 10:00 AM
sw07gt's Avatar
Default 4L80e HD2 Shift kit: How much power?
The description says it holds big horsepower but I'm just curious if anyone has experience making big power with it.
Old May 23, 2012 | 10:30 AM
maddoglou454's Avatar
Hey my man! If it's anything like our Level 4 4L80e, we make ours hold up to 1200HP
Old May 23, 2012 | 05:04 PM
Jake's Performance's Avatar
The TransGo HD-2 kit for a 4L80E is the best kit available to bolt into a transmission without taking it apart BUT it has its limits.
I would say the limit is going to be around 850 ish or so. It may live a bit longer in some applications (lightweight).
The sandwiched seperator plate limits flow to 3rd gear although it does dual feed.
It also has the potential to create crossleaks.
You can do internal mods and use a stock plate for a more effective method.
Our new transbrake and in the near future we'll be offering a non-transbrake valve body assembly that has a revolutionary 3rd gear circuit in the 4L80E.
Old May 23, 2012 | 07:52 PM
sw07gt's Avatar
Im looking to make around 700-750. Sounds like its worth a shot.
Old May 23, 2012 | 08:02 PM
TrickrTreat's Avatar
Ive been making 650+ rear wheel on a mustang dyno for over a year now with my stock 4l80e with the HD-2 kit.
Old Dec 1, 2012 | 12:22 AM
futureuser's Avatar
I like the sounds of this and hope to be pushing my 4L80e with the HD2 to the limits too. So far 10.68 @ 3700# weight.
Old Dec 1, 2012 | 07:42 AM
forcd ind's Avatar
i built my own 80E and added the HD-2 (if the trans apart you can use more of the kit) i weighed over 3900 lbs, street car, but ran 9's with drag radials, made close to 650 RWHP
actually started out with the HD-3 kit, but like most wasnt happy with it, swapped out V/B and installed the HD-2, much better setup, esp auto shift on the street
been together 3 years, still perfect
Old Dec 1, 2012 | 09:03 AM
stevebbc's Avatar
Default transgo intermediate clutch springs
I'm in the middle of my first 80e build. Going with stock rebuild except for the kit. Did you guys use the intermediate clutch replacement springs in the kit. It sounds simple but I'm wondering how easy it is to get the spring retainer assembly back together.
thanks,
Steve
Old Dec 20, 2012 | 02:48 PM
nichoms's Avatar
Jake,
Does your calibration kit accomplish the same as the Transgo HD kit? I ordered your kit but am confused on if it does similar dual feeding as the HD2...
With your 4L80E Calibration kit, could I expect similar HP capacity as I would from the HD2 kit?
Thanks,
Nick
Old Dec 27, 2012 | 07:02 PM
RedMilleniumZ28's Avatar
Originally Posted by nichoms
Jake,
Thanks,
Nick
I would like to know the same thing also!!!
Old Jan 10, 2013 | 09:02 PM
lunati397's Avatar
Me too and Plus 1 for Jake best customer service ever and I havent bought a thing from him yet
Old Jan 10, 2013 | 09:19 PM
My calibration kit for the 4L80E limits fluid flow to unnecessary circuits for quicker apply.
The TransGo kit works OK. I'm not a big fan of the sandwiched separator plate and we experienced some delayed 2-3 shifts when we've used it in the past.
I've also seen some weird pressure issues using their pressure relief setup.
I would use the TransGo kit instead of mine if the kit is being installed with the trans in the vehicle.
Mine is more oriented for installation during a rebuild. I can offer a VB assembly that will work better than anything currently available except my D3 transbrake.
I have to get some parts made in the future but we are going to incorporate some of the design of the D3 transbrake circuits into all of our builds and valve bodies in the future.
Old Jan 10, 2013 | 11:19 PM
Tell us more about this valve body. What all does it do? Do u still use your calibration kit? And price? I'm going to be rebuilding an 80e in a few weeks!
Old Jan 24, 2013 | 09:00 AM
LS1FREEK's Avatar
13 Second Truck Club
I have the same questions!! ^^^^
Old Jan 25, 2013 | 09:31 PM
LongIsland63SS409's Avatar
interested also.
Mike
Old Feb 12, 2013 | 04:39 PM
Originally Posted by LongIsland63SS409
interested also.
Mike
Still Interested???????
bump
Old Feb 12, 2013 | 05:14 PM
https://ls1tech.com/forums/17048288-post12.html
I'm not sure what else to answer here.
My valve body recalibration kit is designed to be installed during rebuild for best results.
It's NOT for a mild combo with softer shifts or towing. It's for a serious setup that is making power and you need immediate clutch apply.
In short is shifts fairly hard at all times.
It is a seperator plate, accumulator blockoff plate, gaskets, bolts, and boost valve kit. It's fairly simple to install aside from the internal mods, which are not difficult but require almost complete disassembly.
Old Feb 12, 2013 | 06:10 PM
O sorry but from your post you said "I can offer a VB assembly that will work better than anything currently available except my D3 transbrake." Which made us think u had a valve body not just the calibration kit!
Old Feb 13, 2013 | 12:05 AM
Ahh,
I gotcha. I have plans to make some VB's but need to make some of the parts associated with it and I already have a backlog of projects at the machine shop.
Old May 20, 2015 | 03:32 PM
SILVERBIRD97's Avatar
Jake can we use your manual control box with the trans go shift kit?
