Temp sender in fluid test port (4L80)
Old Jun 1, 2012 | 08:00 PM
DietCoke's Avatar
Default Temp sender in fluid test port (4L80)
Any issues with doing this with the temp sensor gage sender? Seemed a logical place to put it, in the fluid test port.
Old Jun 1, 2012 | 09:56 PM
Jake's Performance's Avatar
No issues. It will work fine.
Old Jun 1, 2012 | 10:02 PM
ta02zx10r's Avatar
Where's the fluid test port?
Old Jun 6, 2012 | 05:40 AM
DietCoke's Avatar
Works great, temp sender screwed right in
Old Jun 6, 2012 | 01:33 PM
slow67's Avatar
Gingervitis Addict
It works ok, but it reads case temperature, not fluid temperature. Reads high under normal use, reads low when racing.
Old Jun 6, 2012 | 01:40 PM
01ssreda4's Avatar
Put it in the pan, it's a better average temp reading IMO.
Old Aug 27, 2014 | 12:57 AM
g8lover's Avatar
Sorry about renewing an old thread.... but just curious if there is a max length of sender before it will cause issues... the sender I got seems long and not sure if it will hit something on inside or block something.... I got a glowshift temp sender....
thoughts???
Old Sep 3, 2014 | 11:02 AM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
think mine about a inch long but it isn't the same size all the way. Got defi gauge with temp unit and it fits in there no problem.
Old Sep 3, 2014 | 01:22 PM
LFSADRG's Avatar
thoughts???
AutoMeter 2253 is the long version. Use AutoMeter 2254 for the short version. I had the same problem and now use 2254.
http://www.summitracing.com/parts/atm-2254
