4l60e Refresh Issues
Old Jun 11, 2012 | 09:46 AM
Mystery Bird's Avatar
Default 4l60e Refresh Issues
Pulled my 4l60e and freshened it up when I built new motor. It will not shift into third under WOT and is slipping in 4th under hard throttle. I must have put something back together wrong because it's new 3-4 clucth pack. Thoughts before I tear this back out of car and rip it apart?
Old Jun 11, 2012 | 10:55 AM
bernarlitt's Avatar
Last time my trans did that on a fresh rebuild , it ended up being the vss going bad. Not saying this is your problem but its definitely worth a shot
Old Jun 11, 2012 | 09:49 PM
mrvedit's Avatar
Moderator
This sounds like the 3/4 clutch is slipping.
Did you air test the input drum before final assembly?
What 3/4 clutch clearance did you have?
Did you use a stock or performance clutch pack?
A leak in the 3rd accumulator check ball, a leak in the 4th accumulator or a ripped teflon seal on the input shaft could cause 3/4 slippage too.
Old Jun 12, 2012 | 07:08 AM
I used Raybestos 7 disc setup this time, new 3rd check ball, and all new teflon seals. I did check with air and the clearance was within what the ATSG manual called for. Could that clearance be too much for this setup? Can't remember what it was off the top of my head, I did check clearance dry.
Old Jun 12, 2012 | 08:30 AM
mrvedit's Avatar
Moderator
Wow, sounds like you built everything very carefully.
Clearance isn't critical, anything in the .025 to .090 range will work (many recommend in the .035 to .050 range), but if you accidentally used thinner frictions or steels, you could end up out of range.
I have not replaced a 3rd check ball myself yet, so don't know how error prone that might be.
Other than perhaps checking for a leak on the 2nd servo piston, I cannot think of anything else that could be checked before removing the trans. I'm hooking up with my local trans builder friend today; I will ask him too.
Bummer!
Old Jun 12, 2012 | 09:36 AM
That is one thing that came to me this morning is the Sonnax 2nd and 4th servo setup. Wondering if the new seals got twisted or something binding.
Old Jun 12, 2012 | 01:38 PM
mrvedit's Avatar
Moderator
I just talked to my trans builder friend and had him read this post.
He wanted to know if the 1-2 shift is firm and double check that there is no slippage in 2nd. Next, a pressure check in Park and Reverse would be useful; your local trans shop could do that in 10 minutes.
Even if you decide to just pull the trans and rebuild it again, the problem might not be obvious. Therefore, the more info we have from your "semi-working" trans, the better we can pinpoint the likely problem area.
Checking the servos is certainly a good idea. With the servos out, you can also verify that the 3rd checkball is loose.
Old Jun 12, 2012 | 02:19 PM
1-2 shift is fine, didn't notice any slippage in 2nd, well, except the tires. Under normal driving it shifted fine, just slipping in 4th and no WOT 2-3. I wouldn't waist time rebuilding again just pull apart for inspection. I'm going to replace the separator plate to see if that changes anything. I did use the torlon ***** this time with the old plate. Didn't change it before cause it only had about 10k miles on it.
Old Jun 12, 2012 | 10:03 PM
mrvedit's Avatar
Moderator
No harm in putting in a new separator plate and gaskets.
Transgo sells a good "universal" plate. You will probably want to drill out the 2nd and 3rd gear feed holes a bit. Drilling out the 3rd feed hole will help overcome any small leaks in the 3rd clutch circuit. IMO at least .082 and perhaps even .091. (More if you use the Sonnax check valve.)
I'm using the torlon ***** in my current trans.
(I'm trying to finish another trans, but keep taking it apart to answer questions here.)
Old Jun 13, 2012 | 06:29 AM
I'm not sold on that Sonnax check valve yet. I actually have it but never put it in.
Old Jun 13, 2012 | 08:43 AM
mrvedit's Avatar
Moderator
I wasn't either until my local trans builder friend said he has been using it in all performance rebuilds. Several other people here have mentioned having it too.
I have it in my current trans which I took to the track last week. I programmed the shift points at 6500 RPM and my scanner shows the max rpm at those shifts was 6550; no flare at all, even with torque management disabled. Of course for a real test I would have to remove it and test it at the track again; not doing that. I do find that all Sonnax products are well engineered.
I wasn't really recommending it; I was just trying to be very careful about the 3rd feed hole size. I know hundreds of other people read these threads and I try to be very thorough and accurate.
BTW - If you are running a 11.6 ET, IMO you really should have a shift kit in the trans. At least to increase line pressure with a .500 boost valve and/or stiffer pressure regulator spring.
Old Jun 13, 2012 | 10:40 AM
Oh, should mention this is not the first time the trans has been touched. I simply did a refresh and added a few more performance hard parts since it was out of the car.
Parts List:
Partial Transgo HD2 Shift Kit
All Sonnax accum pistons
Dual roller sprag
Torlon *****
All Molded GM steel pistons
Sonnax 2 and 4 servos
HD reinforced band
HD pump slide spring
Rapid release valve
Beast sunshell
Boost valve... that's all I can remember off the top of my head.
Old Jun 13, 2012 | 11:19 AM
mrvedit's Avatar
Moderator
Good you know all the parts before I suggest how to drill the separator plate.
I would first check the servo seals very carefully. 2nd get a new separator plate and drill it according to the Transgo HD2 kit directions, but go to .101 on the 3rd feed hole.
Something people miss is that even in 3rd and 4th gear, the 2nd servo is full on; however since the 3rd fluid has more surface area on the back of hte 2nd servo, it pushes it back and releases the band. IMO, the bigger the 2nd servo is, the bigger the 3rd feed hole should be.
Unfortunately this does not explain the problem of slippage in 4th.
Still, check the servo for leaks which can cause all kinds of strange problems.
Old Jun 16, 2012 | 04:08 PM
IT'S FIXED!!! I pulled the Sonnax 2-4 servo setup and swapped it for a Fairbanks setup I had in another trans, new separator plate, and just for insurance I changed the EPC solonoid and the pressure manifold. Shifts through 1,2,and 3 at WOT without a hiccup. Holds 4th locked up perfect.
Old Jun 17, 2012 | 09:09 PM
mrvedit's Avatar
Moderator
Glad to hear you got it shifting and holding 4th now.
Congrats!
Did you use the separator plate as-is, or did you drill it? If drilled, please tell me the hole sizes for the 1-2 and 3rd feed holes.
Old Jun 18, 2012 | 06:59 AM
I drilled it to .093.
