trans temp gauge
I am getting a torque converter in a couple months and I'd like to get a trans temp gauge at the same time. I will be having a shop install it and tune the car but I don't know what I would need to hook up the gauge. I know I'll need the gauge itself and a gauge pod or something to hold the gauge. I know you can weld a bung onto the trans pan (it will be a stock pan), are there any alternatives? I planned on getting some Auto Meter gauge around $60 but idk which one since they have so many. Also heard about this Aeroforce Interceptor that is a trans temp gauge and a bunch of other stuff for more money and hooks into the OBD2 apparently?
What kind of setup do you guys specifically run?
I have an flt lvl3 Trans with a yank ss3600 and a big tube and fin cooler and I typically see 180 degrees max in traffic on a 90 degree day and that's reading from my gauge.
Whenever I upgrade my trans I'll do an FLT lvl 3 or 4 but I hopefully won't have to do that for a while. I'm thinking about a 30k GVW cooler from Hayden, plate style, since those are more efficient than tube and fin.
roughly 10 degrees is what I was told. just for reference my flt lvl3 is a nice piece, the car its in is my dd.
Plus, every time you open a cold one, you will get annoyed not having a good cup holder to put it.. LOL
You said temps got cooler when you changed trans coolers, so what did you have before and what you using now?
Also, I am on the fence about using the stock cooler in conjuction with the external one. Only because I drive mine in the cold..
i had a B&M 70264 plate style cooler ran with the stock cooler at first then by iteslf. i didnt like where it was on the can and found a better/bigger cooler for my setup heres the tube and fin type cooler i have now...http://www.summitracing.com/parts/FLX-3820/
I decided to bypass my stock one and i live in CT. when the weather gets cooler maybe ill run both again but probably not. just let it warm up a little bit before driving in the cold.
Like the 70264 w/ stock cooler in various conditions, 70264 by itself in those conditions, new Flex-A-Lite in those conditions?
Main reason I am asking is because while the tube and fin flex-a-lite is bigger, it's a more inefficient design and it has a lower GVW rating than the 70264 does.
I had both cooler in the same location on the condenser so there is good air flow. i had my b&m up a little higher than were the new one sits due to the tubing came in from the bottom vs. on the side. i also factor the size difference in the 2. the tube/fin is probably double the size of the b&m.
Thanks man I appreciate it!
As far as the gauge goes, I was looking at my budget and I believe I may actually just go with an autometer gauge rather than the interceptor to save some money up front even though the interceptor does so much. I may get a 2 gauge pod though so that I can get one later when I have more on the car I want to keep track of.
