LS1 with th400 trans, PCM question
Old Jul 18, 2012 | 05:47 PM
loyaltyisking's Avatar
Default LS1 with th400 trans, PCM question
What do I need to tweak to run a th400 trans with my 2000 SS motor? I am debating on switching the trans to one that would match the SS motor, but I think using my old trans will be cheaper. I know bout the flywheel and crank spacer.. But I dont have a clue about the computer working with the old trans. Any info, or direction would be greatly appreciated
Old Jul 18, 2012 | 06:20 PM
MUSTANGBRKR02's Avatar
Most people flash them to a M6 tune so you don't have codes or anything. I also tapped my ABS for the speedo so the idling portion is correct.
Old Jul 18, 2012 | 06:27 PM
Its going into a 72 C10.. Do I have to worry about codes? Will it throw the computer off if I just leave the connections to the trans disconnected?
Old Jul 18, 2012 | 06:28 PM
Excuse me if the answers obvious by the way...
