4l80e interchange
Old Aug 7, 2012 | 05:57 PM
tjb406's Avatar
Default 4l80e interchange
would a 96 suburban 4l80e work behind a 2001 lq4 with the 0411 computer. or would there be modifications that would need to be made?
Old Aug 8, 2012 | 04:48 PM
slow67's Avatar
Gingervitis Addict
Yes. You will have to modify the cooling lines (later style has 1 front and 1 rear, instead of both up front). Also the rear cooling line fitting in the transmisison won't work if you try to move it up to the front.
Old Aug 8, 2012 | 07:14 PM
tjb406's Avatar
realy just concerened about the electronic aspects. i can physicaly make it fit,thats no biggy.
Old Aug 8, 2012 | 07:17 PM
GMRACER13's Avatar
The transmission will be compatible with the PCM but you will need to add the wiring in the vehicle's harness for the input speed sensor.
Old Aug 9, 2012 | 09:20 AM
slow67's Avatar
Gingervitis Addict
Sorry, I was thinking you were putting an 80E in place of another 80E that already existed. As far as details, check the 4L80E sticky.
