racing with 4l60e issues on 3d
Reason been last night I tried shifting from 2nd to 3d and she bounced of limiter a few times [ongoing issue] then I said the hell with it and tried again but skipped 3d as the rpms got closer to redline and went to D and it shifted fine. Dunno if that's another option going to OD or will it hurt anything ? any input is appreciated...
Manually upshifting can, however, cause you to hit the redline if you don't shift soon enough. While the electronics in the trans act instantly, the hydraulics in the trans take longer. So, even if you shift before the rev limiter, the hydraulics in the trans will be slower and might cause you to bounce off the limiter. You can't shift better or faster than the computer can. If you are having issues with the trans short-shifting, you need to get a tune.
That downshift can be a real pain when roll racing from what I've heard.
Before
http://youtu.be/9GNoSMuNTXU
After
http://youtu.be/gAkGV_klNeA
