4l60e
Old Aug 29, 2012 | 10:32 AM
jurstin86's Avatar
Default 4l60e
Got a problem with my tranny, lost 1st and 4th gear all I got is rev., 2nd and 3rd. Cannot figure it out any help would be great. It jus skips 1 and goes to 2.
Old Aug 29, 2012 | 07:20 PM
mrvedit's Avatar
Moderator
Your symptoms indicate that shift solenoid "A" (sometimes called the 1-2 shift solenoid) is defective. Since shift solenoids are only $15 each, I would start there. Buy the solenoids, drop your pan and replace them. The only tool you need is a slotted screwdriver to pull out the clip that secures the solenoid. Then pull out the two side-by-side shift solenoids to replace them. One is spring loaded, the other is not. Remember to put the clips back. If you really only want to replace one, let me know and I will post a pic of which is is "A".
Old Aug 29, 2012 | 11:11 PM
jurstin86's Avatar
If u could post a pic....that would help.
Old Aug 30, 2012 | 08:52 AM
mrvedit's Avatar
Moderator
OK.
First, you need to jack the front of the car up; for safety use jack stands.
Since most trans don't have a drain plug, I highly recommend pumping oil out through the dipstick using a $10 hand pump. Using a clean and dry 1 Gallon milk jug, you can also save and reuse the expensive trans fluid if it is in good condition and not discolored (brown). You should be able to pump out close to 1 gallon (4 quarts):
Next, drop the pan carefully as there will still be oil in in. Position it on the ground exactly below the trans as the internals will drip like crazy.
You will notice a large oil filter which you don't even need to remove (it twists out by hand).
Here is a picture, without the oil filter, of what you will see:
Solenoid "A" is the upper one on the right side of that picture. Remove the snap-on electrical connector. Then push the solenoid in a bit and use a screwdriver or pliers to remove its clip. It is spring loaded and will pop right out. Push in the new one, insert the clip and snap on the electrical connector.
As this point you will probably be thinking it took a bit of effort to get this far; hence my suggestion to replace the other shift solenoid too. Replacing the oil filter might be a good idea too.
If the trans fluid is discolored, I would recommend replacing it and the filter.
BTW - if you replace the 5 quarts that you now have out, that is still only about half of the 10-11 quarts that the trans and torque converter hold.
I hope that helps and that my diagnosis is correct.
Old Aug 30, 2012 | 09:20 AM
jurstin86's Avatar
Thanks, I hope this does fix it....what about limp mode? I was told it is in limp mode...
Old Aug 30, 2012 | 10:12 AM
mrvedit's Avatar
Moderator
In limp mode you will only have 3rd gear and Reverse. If the PCM detects problems with any of the solenoids or other electrics in the trans, it will enter limp mode.
If you are in limp mode, then the "Check engine" light is like on. Most auto stores will let you borrow a good scanner to check the codes which should indicate what the PCM thinks is wrong.
Old Aug 30, 2012 | 10:52 AM
jurstin86's Avatar
I have turned off all the mil lights. Using HP tuners. I jus haven't had time to check it out yet
Old Aug 30, 2012 | 11:57 AM
mrvedit's Avatar
Moderator
I tune with as many MIL lights as possible as they may give you an early warning of a problem.
Obviously if you have HP Tuners you don't need to borrow a scanner.
Let me know what codes, if any, the PCM is reporting.
Old Aug 31, 2012 | 08:39 AM
jurstin86's Avatar
Shift soleniod 1-2 electrical. Is the code.
Old Aug 31, 2012 | 03:27 PM
Agent_Orange_Shuvel's Avatar
then just like mrvedit said it's either that solenoid or the wiring going to that solenoid
Old Aug 31, 2012 | 04:28 PM
jurstin86's Avatar
I'm gonna replace the soleniod and the harness. Iv heard the clips break easy
Old Aug 31, 2012 | 05:31 PM
mrvedit's Avatar
Moderator
Sounds good. Note that the harness generally includes a new TCC solenoid which is good too. Just be sure you get a harness which matches the connector on your pressure control solenoid (sometimes called Force motor) as that changed somewhere around 2002. My picture above shows the new style connector; I believe the old and new style pressure control solenoids are interchangeable.
Check out this page for ordering these parts:
http://www.transmissionpartsusa.com/...ids_s/5561.htm
Crazy that the 2003 harness is double the 2002 harness and the only difference is the connector for the pressure control solenoid. (Otherwise I would have recommended getting a new style pressure control solenoid too as they can get flaky and give strange symptoms.) I think my local trans shop sold me a 2003 harness for $35; so there must be cheaper vendors for that year.
Old Sep 1, 2012 | 03:13 PM
SSdimension's Avatar
mrvedit you got yourself an awesome camera haha
Old Sep 1, 2012 | 08:33 PM
jurstin86's Avatar
Thanks mrvedit...u kno Ur stuff
