th350 problem after ATI sprag installed
Old Sep 3, 2012 | 07:33 PM
mdacton's Avatar
Default th350 problem after ATI sprag installed
Keeps pushing fluid out of vent
Have had rebuilt it since 2 times have had converter restalled/rebuilt 5 times and swapped converters also
Trans ran perfect for 3 years 300 passes looked like new when taken apart, but wanted to upgrade sprag.
nothing but problems since but also restalled converter at same time. If anything its a half quart or less low. it is not overfilled 7quarts with a 8" converter.
pump surface is flat pressure look ok its forward manual cheetah VB. the linkage is good. cooler pressure is 40psi. line pressure is 175 in all ranges.
6 weeks and same problem
Old Sep 3, 2012 | 08:57 PM
Jake's Performance's Avatar
I highly doubt the drum is your issue. Fluid venting has several causes but sometimes the solution is simply a catch can.
You might put a low psi gauge on the vent and see if it builds pressure in any certain gear or circumstance.
Are you checking the fluid running and hot?
Old Sep 3, 2012 | 09:20 PM
mdacton's Avatar
yes checking it running and hot
Old Sep 3, 2012 | 11:23 PM
Vince B's Avatar
Moderator
Have you changed anything with your cooler or lines for this trans since this all started to happen? I have seen restricted coolers cause this issue in 4L60E transmissions just throwing this out there.
Old Sep 4, 2012 | 06:08 AM
mdacton's Avatar
cooler lines are the same and free flowing as well as the cooler
