6L80E replacment parts???
Old Sep 5, 2012 | 05:33 PM
DiabloSS's Avatar
Default 6L80E replacment parts???
Hello i have a 6l80e from a silverado and i am need of some "Pump Gears" as my tranny tech calls them, i cant find replacment parts for it anywhere nor do the parts come out in diagrams or have Parts#s at dealership i have taken a pic of the parts i need they go along w/ the oil pump and bellhousing, help! Thanks!!
As you can see the gear in the middle cracked due to incorrect installation of torque convertor stall
Any one with info on parts or a 6l80 for parts? Thanks again!
Old Sep 5, 2012 | 06:58 PM
mrvedit's Avatar
Moderator
Those look exactly like 4L60 pump parts.
Could you please measure that part's ("rotor") thickness and width, preferably with digital calipers. Also measure the vanes and the rings.
I see that it is a 13-vane rotor.
Old Sep 5, 2012 | 07:29 PM
Circle-D's Avatar
They look just like the 4L60 stuff, but they are a little different. I think the only way to get a new 6L80 rotor is from GM in a new pump - not 100% sure though. Make sure you check the converter hub if it was an install error. It could be damaged as well.
Chris
Old Sep 5, 2012 | 11:12 PM
DiabloSS's Avatar
By any chance Chris would you guys at CircleD have any used 6l80e parts like da 1s pictures that you can sale me, let me know asap! Thanks!!
Old Sep 6, 2012 | 07:36 AM
Circle-D's Avatar
Sorry, I do not have anything. I think I heard of somebody making a billet rotor for the 6L80. That might be cheaper than a whole new pump from GM.
Chris
Old Sep 6, 2012 | 12:56 PM
DiabloSS's Avatar
Thanks Chris any chance you or anyone has contact info of where i can get this billit rotor, thanks!
Old Sep 6, 2012 | 01:00 PM
DiabloSS's Avatar
http://www.transmissioncenter.net/6l...arts_6l90e.htm
Got this site the billit rotor is 175.00.... Im sticking withngetting a oem stock one cuz da billit one is expensive...
Old Sep 10, 2012 | 12:43 AM
DiabloSS's Avatar
This is the Part# 24248571 for this rotor package kit "pump gears" its around $130 at dealer or $60 on amazon......hope dis helps some1 out 1 day.
